Light direction in scenaries
musicaldoc
Post by musicaldoc »
Hi, I need to change the light direction in the scenary Dietesdorf_Tables in order to have the shadows exactly under the models, as if the sun was at the zenith.
I have opened and edited the Dietersdorf_Tables.xml file in the Skybox directory, changing the <Lightdir> values but nothing changes, how can I do it please?
Thank you.
Re: Light direction in scenaries
Hi, that is the right way o do it. What values did you use?
musicaldoc
Hi Michael, thank you for answering.
I was editing the wrong file... I was working on Dietersdorf_Tables.xml file because I thought that that was the one used in the Dietersdorf_Tables Scene.
I instead noticed in the code that the one loaded is the Dietersdorf.xml, so working on it I finally today solved my issue getting the sun from where I need in the Dietersdorf_Tables scene.
Just one question, I'm toggling on the matrix when I work on objects and positions, but it's difficult, at least for me, to understand the values of the grid of the specific environment, is there a way or a place where I can see the values of the grid lines in order to work more fastly instead of trying randomnly?
Roberto
Yes: Turn in the status line, toggle the status file format until it shows the position of the helicopter. Then you cn use these coordinates...
musicaldoc
Great, found it, thank you Michael!
Roberto
