Windows 7 64-bit black screen
woodflute
Post by woodflute »
Hello. I have been running Heli-x 4.2.1254 and am a registered (paying) customer.
I have downloaded the new version 5 but only get a black screen with no menus after completing controller setup. I can hear the helicopter motor.
My graphics card is an AMD 7950 with the latest driver Catalyst 13.12 installed.
Computer details if you need them: OS is Windows 7 Ultimate 64-bit, CPU is Intel 3750K, 8 GB RAM, sound is X-Fi Elite Pro. Screen resolution is 1920 x 1080.
Please advise on any steps you would like me to try.
Thanks.
Re: Windows 7 64-bit black screen
Hello
do you get any messages in the console window?
woodflute
Post by woodflute »
The last two lines are
Controller configuration file found: C:/HELI-X5/files/controller/PPM.xml
Controller configuration file C:/HELI-X5/files/controller/PPM.xml read
Nothing else below that.
The program seems to think it's running: on the top of the black window I get this text in the window border:
HELI-X 5.0.1401 - Demo-Version - Dietersdorf - Logo 600 - FPS: 225
Maybe a update (or downgrade?) of the driver might help. You need openGL 2.0.
woodflute
Post by woodflute »
This driver has OpenGL 1.1 through 4.3 compliancy.
I have just tried Heli-X 5 on another system, Windows 7 64-bit Home Premium, AMD 6870 video card, same driver, same black screen with no menus.
woodflute
Post by woodflute »
Found a work-around: minimize the window with the black screen, then restore the window. Bingo--visible graphics.
Lightstrid
Post by Lightstrid »
I also experienced the black screen. I became a black screen After running the registration.
The cause is a resource file of Heli-X5. Download the file in the "Add a new airport". And Download the "Add" of all, if possible. Because additional data not included in the Heli-X5 that you downloaded.
In addition, Heli-X5 does not work in full-screen mode. It does not seem to work only in window mode as well as X4.
woodflute wrote:Found a work-around: minimize the window with the black screen, then restore the window. Bingo--visible graphics.
Thanks. Great info.
Lightstrid wrote:I also experienced the black screen. I became a black screen After running the registration.
After the activation just select the airport Dietersdorf again.
And yes, the other airports have to be downloaded then (Options->Look for new airports). It is the same with the helicopters.
Fullscreen: It is not supported at the moment. In a beta stage it works here but it is not pactical at the moments since many input dialogs are windowed.
frajag69
Post by frajag69 »
also bei mir läüft er auch im Vollbildmodus ..... kommt mir nur vor als würden die Werte die ich in den Sender eingebe nicht so angenommen werden wie im helix 4
