Windows doesn't see the controller :(
Posted: 11 Apr 2015 17:59
by Nitch
I'm no Windows or computer geek.
I have Windows 7 and have both Heli-X and FlightSim 7.5. Neither seems to recognise the controller.
The controller is a Spektrum DX4e which was purchased recently from a model shop for use with sims.
All of this is new. I have never had the setup working before.
I don't recall getting any drivers for the controller either.
Can anyone help please?
Re: Windows doesn't see the controller :(
Posted: 11 Apr 2015 21:40
by JS1
make sure you got the right USB adapter cable. The Phoenix especially does not work as it uses a proprietary dongle. Other cables come with a small switch for different simulators. Usually any cable suited for FMS will also work with Heli-X. Others may work too. The controller should be recognized simply as joystick device and can use the standard driver of windows (which should not be blocked from installing of course).
