PPJoy for Linux
PPJoy for Linux
to connect your transmitter with your sondcard on Linux try this: http://rc.zexos.org/txppm.html
Um den Sender über die Soundkarte mit dem Rechner zu verbinden, gibt es jetzt das: http://rc.zexos.org/txppm.html
Thanks to Tomáš 'ZeXx86' Jędrzejek
desmogod
Re: PPJoy for Linux
Post by desmogod »
Has anyone managed to get this working?
Having huge issues in Ubuntu 9.10
ZeXx86
Re: PPJoy for Linux
Post by ZeXx86 »
desmogod wrote:Has anyone managed to get this working?
You should read README first, you have to install one required library - PortAudio + PortAudio developer version (contain headers needed for compilation) and linux-headers (it is probably installed by default) for kernel module.
Then there shoul'nt be any problem with it.
Remember, you have to own cable for connection between your transmitter and sound card (input - line in or mic in).
Check README for more info..
Thanks
ZeXx86
Re: PPJoy for Linux
Post by ZeXx86 »
New version 0.0.4 is available now !
It implements CCPM 120° support which is mostly used in helicopter transmitters.
From now, almost all transmitters should work correctly with this software.
Download from HERE
ZeXx86
Re: PPJoy for Linux
Post by ZeXx86 »
New version 0.0.5 is here and brings full support for Spektrum transmitters (DX6i, DX7, etc).
For correct function use value 2 as second parameter.
