Rev 2443
For the beta test. Do not forget to mention your computer system if it might be relevant
Rev 2443
You may update to Rev 2443. New
Key assignable to a switch color (1-10) function which can change all, colors, textures and materials...
The language files are adapted accordingly.
Have fun and thank you for the feedback.
swash23
Re: Rev 2443
Post by swash23 »
maybe not specific to this version, but after getting a 4k monitor and changing the resolution settings (to 3840x2160) and the font size (to 32 (4k)) I see 2 problems:
* sometimes in full screen mode the mouse pointer is not visible (independent of the setting 'hide mouse pointer')
* the 'show sticks' HUD moved out of the visible screen. There seems to be no way to bring it back.
Regards
Re: Rev 2443
Are you on Windows or MAC OSX?
Please try "factory settings" in the simulation menu.
swash23
Re: Rev 2443
Post by swash23 »
I am on windows 10 64 bit
swash23
Re: Rev 2443
Post by swash23 »
the timer (HUD => show timer) consumes 50 fps in my case :roll: . Please see the following video: https://file.io/O9i0hz9DrFqs
Regards
Re: Rev 2443
ok, the timer is updated in 2444 ... ;-)
modellermark2
Re: Rev 2443
Post by modellermark2 »
There is a Java update available - Version 8 Update 311 - is it OK to update to that or will it affect Heli-X?
Thanks, Mark
Re: Rev 2443
modellermark2 wrote: 15 Nov 2021 07:55 There is a Java update available - Version 8 Update 311 - is it OK to update to that or will it affect Heli-X?
Thanks, Mark
Hi, V10 comes with Java 11, V9 with Java 8. On which operating system are you?
modellermark2
Re: Rev 2443
I am on Windows 10 Pro all up to date and have Heli-X 10 installed - odd that I should be on Java 8 then although I do have one other piece of software that uses Java.
Has it been tested on Windows 11 as I have that available as an update too?
Re: Rev 2443
swash23 wrote: 14 Nov 2021 13:55 * the 'show sticks' HUD moved out of the visible screen. There seems to be no way to bring it back.
Please update to 2447. Now the HUDs should come back after restart....
